3.10 label layer change not working?
4590
7
09-04-2014 06:07 AM
WalterEralio
Upgrading to 3.10 I found in the documentation at what's new ( What's new in Version 3.10 | Guide | ArcGIS API for JavaScript )
Label layer changes: Labeling expressions no longer use ${field} syntax but now use {field}. In other words, popup template syntax instead of info template syntax.
I've changed it accordingly and the {CASENUMBER} text is displayed instead of the value
lomaLabels.addFeatureLayer(featureLayerLOMA, lomaLabelRenderer, "{CASENUMBER}" ,{pointPriorities:"AboveLeft"});
I really need this since I'm struggling with ${} been confused with a TAG and my program blows out with the error org.apache.jasper.JasperException: The attribute prefix CASENUMBER does not correspond to any imported tag library
WalterEralio
IT WAS WORKING FINE!! my bad!! I was hosting the API and replacing the HOST name I accidentally post to the old api (3.7)
TIM WITT: THANKS FOR YOUR HELP!! and quick response!!
TimWitt2
Walter,
try this:
var labelField = "CASENUMBER";
lomaLabels.addFeatureLayer(featureLayerLOMA, lomaLabelRenderer, "{" + labelField + "}" ,{pointPriorities:"AboveLeft"});
Let me know if it works.
Tim
TimWitt2
Also make sure that you changed the api to 3.10
<script src="//js.arcgis.com/3.10/"></script>
<link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.10/js/esri/css/esri.css">
WalterEralio
TimWitt2
Im glad you got it figured out
JssrRR
Tim,
I need some help figuring this out, I am trying to do something similar, but once I add the label layer, the feature layer is not showing up.
I have added this, among other required
require ([ "esri/layers/LabelLayer",
  "esri/renderers/ScaleDependentRenderer"
function( LabelLayer, ScaleDependentRenderer
        var featureLayer = new FeatureLayer("http://services1.arcgis.com/hVMNhMnY75fwfIFy/ArcGIS/rest/services/NursingFacilities/FeatureServe                    mode: FeatureLayer.MODE_ONDEMAND,
          outFields: [labelField]
      var labelField = "FacilityID";
      var NFColor = new Color("#444")
  // create a text symbol to define the style of labels
        var NFLabel = new TextSymbol().setColor(NFColor);
        NFLabel.font.setSize("12pt");
        NFLabel.font.setFamily("arial");
        NFLabelRenderer = new SimpleRenderer(NFLabel);
        var labels = new LabelLayer({
        // tell the label layer to label the Nursing facility feature layer
        // using the field named "FacilityID"
        labels.addFeatureLayer(featureLayer, NFLabelRenderer, "{" + labelField + "}");
        // add the label layer to the map
      map.addLayer(labels);
     // scale dependent renderer for NF labels
        var NFRenderer = new SimpleRenderer(NFLabel);
        var NFScaleDependent = new ScaleDependentRenderer({
          rendererInfos: [{
            renderer: NFRenderer,
            minScale: 500000,
            maxScale: 1
        var NFOptions = { pointPriorities: "AboveCenter" };
        labels.addFeatureLayer(featureLayer, NFScaleDependent, "{FacilityID}", NFOptions);
       FeatureLayer.setRenderer(NFRenderer);
        map.addLayer(featureLayer);
The feature layer itself is not loading, something is missing or I am not doing it right, any help will be appreciated.
Thanks!
TimWitt2
JssrRR
Tim,
I added the correct link, but that did not help, probably something else needs to corrected, still working on it.
Thanks for the help.
