I am a developer of GIS Web components, and I would greatly appreciate it if the logic that converts a MapView into a WebMap_as_JSON could be exposed in a public method. We run a custom printing service that uses the Export Web Map Task geoprocessor with extra parameters to enable the printing use cases of my Organisation.
Both the PrintViewModel.print() and the print.execute() combine building the payload and sending the request. Exposing the logic that generates the WebMap_as_JSON as a seperate method would benefit our workflow for two reasons.
You can call .toJSON() on the map.
<body>
<arcgis-map item-id="05e015c5f0314db9a487a9b46cb37eca">
<arcgis-zoom slot="top-left"></arcgis-zoom>
<arcgis-legend slot="bottom-right"></arcgis-legend>
</arcgis-map>
<script>
document.querySelector('arcgis-map').addEventListener('arcgisViewReadyChange', (event) => {
const webmapJson = event.target.map.toJSON();
console.log(webmapJson)
</script>
</body>
@Justin_Greco This returns a WebMap JSON which is different from the WebMap_as_JSON specification. Most notably it excludes GraphicsLayers and the graphics contained within them. It also excludes any Graphics that are added to the MapView.graphics property.
