Zone Lookup Issues
10831
45
07-26-2023 01:14 PM
LeviCecil
I'm having issues with Zone lookup. When I enter an address in my school finder app, it shows me the elementary school associated with that address, and the middle and high school boundaries as well. The problem I'm having is, when I click on the zoom on the middle and high school boundaries, the map zooms out, but I still only see the elementary school point. I don't see the other schools. I also want users to be able to see ALL the schools and boundaries in the map on search, with the relevant ones highlighted. Right now everything outside the search is hidden. I've toggled off "Hide layers when app loads" and it doesn't seem to have an effect. Is this a bug?   
PaulCone2
That's great -- looking forward to it.
PaulCone2
Also the map label for the pin is underneath the layer.  Can you put the label on top?20231012_170739000_iOS.png
PaulCone2
Also, clicking on the map or using the Find my Current Location both return No Result Found, even on mobile.  ???
KellyHutchins
Esri Notable Contributor
Do you have data in that area? Is your map public? If so can you share the link so we can take a look.  Do you have a custom locator in the app?
PaulCone2
Yes there is data in that area in our custom locators, and yes it is public -- see my first comment on this thread.
It looks like the problem was with our default geocoder so I changed to another and it works now.
KellyHutchins
We did make some updates to better handle custom locators so that may also be better in the next release.
PaulCone2
We're live with our tool, embedded here...
Portland transition: geographic districts | Portland.gov
I turned off the header to save space but it would be great to be able to reduce the whitespace on the pop-up.
KellyHutchins
 Can you provide details on the white space you want to reduce?  Depending on what you are looking for you might be able to accomplish it with custom css or a more customized popup. If you can describe in detail what you want it to look like I can take a look.
LeviCecil
Having layer effects on doesn't change anything. I have to click "clear search location" to see the other schools around the one in the search. Even though I have "Hide layers when app loads" toggled off. Our enrollment office is asking that parents be able to see the schools in the vicinity of their neighborhood school for transfer purposes. I was able to accomplish this with the District Lookup Widget in WAB, but I have to stop using that now.
Search result:
Search result cleared, other schools become visible:
KellyHutchins
IF your app is public can you share the link and I’ll take a look?
