Sidebar - search results details
674
11-16-2022 02:32 PM
DavidMajor
I think it used to be that when you searched for something in the sidebar app search tool, the results were displayed according how the layer popup was configured in the web map. Now it just shows the display field. For example searching for an address shows just the address in the results, rather than the address, city, and postal code as it does when you click on the feature. Is that expected? Am I configuring it incorrectly?
KellyHutchins
Esri Frequent Contributor
Hi David,
It should still return the feature popup if you have a feature layer search configured. Here's an example with a search layer configured for rare plants. If you search for and select a plant species the layer popup is used.
https://jsapi.maps.arcgis.com/apps/instant/sidebar/index.html?appid=3a32b22d2d994655b4aa587379d03643
KellyHutchins
Hi David,
DavidMajor
Thanks. Something had changed in my feature service. Just needed to remove and re-add the feature layer search to reconnect it. Working now, appreciate the quick reply.
