I know I've done this because I currently have an image in the box for an app that I've made, but I'd like to swap the image for something different. I can't find an image button, and can't find any documentation with any details on this. Does anyone know where I can find some info on adding images? It seems I can drag and drop, but that doesn't appear to be what I did. The HTML (which I don't know enough about to do it that way) points to the item in ArcGIS Online; when I drag and drop, it adds a lot of gunk to the code without alt text.
In the March 2022 update, we've updated the Rich Text Editor to include an image button where you can insert an image via URL.
Please let us know if this update helps and/or if you see any issues!
Best regards,
Ryan
Best regards,
Ryan
I'm working in the Nearby Instant App and the image renders in the editing window but does not render in the app itself. I added the images using the Rich Text Editor. Any ideas? Also I can't seem to get the image to align left, or make it smaller. I see the width attribute but it seems to hit a minimum.
