Hi, i brought this up with customer service, but wanted to see if anyone has had this issue, or has any ideas that could help. I have several workbooks running on our production portal server, and yesterday when i went to check one i found that i am unable to open any of the workbooks. All that happens is they default back to the insights home page. i get this error. I don't think there is anything wrong with the workbooks, but something happened to the insights install. Any ideas on how to diagnose this.
Thanks in advance,
Laura
Not totally sure what's going on here. Are you still able to reproduce the issue? Does the same thing happen in different browsers?
Possibly. When I have noticed something like this internally it usually seems to be a web authentication issue which I imagine could be impacted by modifying the firewall settings.
What type of authentication are you using? Does it work in incognito mode?
Yeah I would try that next. Have you logged a call with Customer Service yet? If the reinstall doesn't work, I would advise that as the next step and then we should be able to dig into the specifics more.
