Using Insights as a Data Quality reporting tool
3381
11
02-15-2022 11:50 AM
NoelWilson
I have several technical questions that I have not found a solution for regarding Insights. I have taken and viewed all available training, I have spoken directly with the instruction from the Instructor-led course and there is no resource to find out if what I want to do is even possible.
1. Use, ingest display Data Reviewer reports as a resource for data quality
2. For one of the metrics, the goal is to find all occurrences when a value is blank or null, but when I try to create a query, and I don not manually removed all values but the null, it returns nothing.  The null values are treated as non-values.  Is this a bug?
3. I would like to create a bar chart to show the results of my queries and generate a percentage and show that percentage ON the bar.
4. Create an interface that can be used at an AF Base connected directly to their SDE database server and repeated for all installations.
These are just a few inquires.  I am trying to create  a proof of concept that is repeatable and adaptable.
Ian_Muehlenhaus
A-ha! I think this is what you need! 🙂 It's easy to export a model and repeat your workflow automatically. It's just kind of hidden.
Let me know if this isn't the solution you're looking for. I think it is, though.
Thanks for asking questions, Noel, and please keep them coming! 🙂
https://youtu.be/Tiy3fZmjAuE
Ian Muehlenhaus
Location Analytics
Quick 3-minute demo of why you need to start using models to save time and reproduce amazing reports at a wicked pace! :-)
Ian_Muehlenhaus
Hi Noel,
I think I accidentally deleted my response with a link. (Very human of me! Sigh...)
Here is a link to a quick video I mocked up that should help save tons of time and stress and in your situation.
You can also export "templates," which means the styling and design of everything is copied. So if you export a Model and a Template, everyone's report should look the same and they can simply change the data file being rendered.
https://www.youtube.com/watch?v=Tiy3fZmjAuE
Here is a more formal and polished demonstration of models. It's shorter too. I need to up my video-recording game.
https://mediaspace.esri.com/media/t/1_5i86hteb/238781633
Thanks again, and thanks for using ArcGIS Insights!
Ian
Ian Muehlenhaus
Location Analytics
