Error when using Import Floor Plans to Geodatabase
1351
03-14-2023 03:43 PM
steveflo
Hello all,
We just got indoors and I was trying to use the tool Import Floor Plans to Geodatabase. I am using the Excel Template File that is provided and ESRI's webpage Configure CAD floor plan mappings and metadata. However, I get this error:
ERROR 180134: Invalid value: invalid literal for int() with base 10: 'B1' in worksheet: Level Properties
I followed the instructions, but not sure why I'm getting the error. My Level IDs look like this UC.BERK.MAIN.CAL.B1.
Any help to steer me in the right direction would be appreciated it. Thank you.
SFrank
Hi @steveflo -- This error message looks like you may be populating an Integer field in the Level Properties sheet with a non-Integer value. Is it possible that you have populated the LEVEL_NUMBER column with the value "B1"? If that is the case, try changing the value to "1" and running the tool.
One tip for filling out that spreadsheet is that there are tooltips in the Excel spreadsheet that can be helpful, along with the Configure CAD floor plan mappings documentation.
GauravJobanputra
@steveflo can you please provide the link to the webpage where you downloaded the Excel spreadsheet from and also please let us know what version of ArcGIS Pro are you on.
steveflo
SFrank solution solved it.
I'm on ArcGIS Pro 3.0.3.
GauravJobanputra
Very glad to know. Don't forget to leave her a Kudo! @SFrank is working on a tool which won't require filling out the sheet. Keep an eye on our announcements for the next release!
SFrank
steveflo
This worked for me. I completely misunderstood the error and thought they were referring to cell B1. I didn't see the tooltips before. Thank you!
