Edit Unit Name using Space Planner
540
05-02-2023 05:50 AM
AndrewBowne
Is there a way to configure Space Planner so a Unit Name can be updated/changed?  We are in the process of a space audit and many spaces have changed names.  I'd like to be able to update the name and name_long of a unit without having to switch to a different app.
GauravJobanputra
Hello @AndrewBowne .. Space Planner currently does not support editing the unit names. It is primarily meant for assignments of units and occupants. The names can be changed in ArcGIS Pro or Map Viewer and the new names will reflect in Space Planner though.
Also wanted to share that we are working on a new floor plan editing web app where you would not only be able to change attributes but also add new units, walls as well as reshape existing ones. It will also have other capabilities like splitting and merging.
