Raster functions through REST
1746
02-21-2020 01:21 PM
PeterHanmore
Is it possible to request an image from an ImageServer service and have an existing raster function applied to it?  We have several pre-defined functions available, as shown by the rasterFunctionsInfo REST endpoint.  I can't find any documentation on how to do this.  I've tried sniffing the connection from arcMap using Fiddler but it doesn't seem to be able to decrypt the POSTed data into a usable format so I can see the syntax being used.
Has anyone been able to do this successfully and can share how they did it?
PeterBecker
Are you attempting this in ArcMap, Pro or through a web client?. The Image Service REST API is extensive. See link. You can pass a raster function request as part of Export Image. This can be a predefined function as defined in the service or a raster function chain. Similar in ArcMap and Pro you can pass parameters for the functions or function chains.
