Pleiades-1 template not functional in MD (ArcGIS 10.5/10.6.1 & Pro)
1321
09-16-2018 08:46 AM
larryzhang
Hello imagery associates,
When loading the bundle Pleiades-1 RAW data (i.e., bundle 0.5m Panchromatic and 2m Multispectral under folders) into Mosaic Dataset, do you witness the following?
  1. The standard Pleiades-1 template (attached) works fine with Mosaic Dataset in ArcGIS 10.4 or 10.4.1.:
          ... Completed crawling 470 data source items. Added 470 mosaic dataset items.
  1. However, this Pleiades-1 template is not functional at all with ArcGIS 10.5/ 10.6.1 and ArcGIS Pro, even though it is applied onto the same bundle Pleiades-1 data folders with all same options:
ArcGIS 10.5/ 10.6.1:
Start Time: Sun Sep 16 13:28:32 2018
2018-09-16T13:28:32.066: Loading raster datasets
2018-09-16T13:29:12.046: Completed crawling 470 data source items. Added 0 mosaic dataset items.
2018-09-16T13:29:12.061: Error: 8004205f: No new mosaic dataset item was added.
Succeeded at Sun Sep 16 13:29:12 2018 (Elapsed Time: 40.06 seconds)
ArcGIS Pro 2.2:
Start Time: Sunday, September 16, 2018 1:12:01 PM
2018-09-16T13:12:04.619: Loading raster datasets
2018-09-16T13:12:49.082: Completed crawling 470 data source items. Added 0 mosaic dataset items.
2018-09-16T13:12:49.095: Error: 8004205f: No new mosaic dataset item was added.
Succeeded at Sunday, September 16, 2018 1:12:51 PM (Elapsed Time: 50.03 seconds)
It looks strange. It should not be a bug, but no other root causes to dig.  I would like to confirm with you, if any similar or reproducible observations.
Tags (1)
RohanGanapathy
Hey Larry , I cannot reproduce this issue using the template you provided.Do let me know if you can share a dataset you used with this template. Send me details at rganapathy@esri.com
Cheers
Rohan
TeamDevS_r_l
Hello, did you resolve this issue? I tried to create a mosaic dataset with Pleiades Product Definition and then I added DIM*.xml. I received the same error Error: 8004205f: No new mosaic dataset item was added !!!
I'm using ArcGIS Pro 2.6
Regards
Antonio
