Max Image Height: 4100 Max Image Width: 15000
1380
08-31-2023 09:13 AM
Tony_J_Van_Der_Wielen
We are trying to publish an image service that has OVERVIEWS, and a Max Image Height: 150000 and Max Image Width: 15000. When we try to publish the service with updated setting in the mosaic dataset, the we only get Max Image Height: 4100 and Max Image Width: 15000.
We are able to publish a service without OVERVIEWS with a Max Image Height: 15000 and Max Image Width: 15000.
Any help would be appreciated!
Tony
udai
Hi
I had the same issue
This worked for me
Right Click the mosaic dataset -> Properties -> Defaults,
In the Image Properties section set the Value to 15000 (it was 4100- by default)
Once you change this Publish / overwrite the service.
PREVIEW
