Does anyone out there know if you can connect to an image server in new versions of AutoCAD for aerial viewing in CAD? My current option is Autodesk Map 2008. Thanks in advance.
The link above will take you to the client for AutoCAD, but this is not compatible with AutoCAD Map. Within AutoCAD Map you may be able to connect to image services serviced as WMS services.
