ERROR 999999 appearing when I try to Classify Objects Using Deep Learning
1087
02-15-2025 08:17 AM
ScarletMaguire
I am trying to classify a set of 160 polygons into categories using a pre-trained Deep Learning model, with the "Classify Objects Using Deep Learning" tool. However I keep getting this message:
"ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds. "
These are the things I have tried/checked:
  • I have Repaired Geometry, so none of my polygon overlap.
  • I have checked that my input raster and all polygons in my input layer overlap i.e. all of my polygons have raster information filling the whole polygon
  • My input raster and polygon layer are using the same coordinate system
  • My output file has been given an appropriate alphanumeric name i.e. no symbols
If anyone can suggest where i may be going wrong, that would be great. Thank you in advance.
DanPatterson
MVP Esteemed Contributor
There are a number of Related links to the right of your question, eg
Solved: Classify Objects Using Deep Learning - Unexpected ... - Esri Community
have your explored those posts?
... sort of retired...
PavanYadav
@ScarletMaguire Can you share some more info e.g. ?
1. pre-trained model name (or link)
2. version of ArcGIS Pro.
optionally, a screen capture of the tool or command
Please make sure you're using a model that is built for Object Classification.
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
