Does the symbology of a raster layer influence how those rasters are processed when creating training samples?
398
02-28-2025 08:39 AM
Labels (3)
ScarletMaguire
I have a lot of 1-band and 3-band raster layers which I will be using as input for creating training samples (the training samples will be used to train deep learning models). My question is, if I modify the symbology i.e. colour scheme, stretch type etc, will these modifications influence the training samples created using these raster layers?
It is my understanding symbology is largely an aesthetic feature. I believe that when using raster layers to create training samples, the information being used is the raw values of each pixel, which as far as I know is not changed by any aspect of the Symbology tab. Therefore, in theory, symbology should not affect the training samples. But I was hoping someone else could confirm it for me.
Ed_
by MVP Regular Contributor
Yes you are correct, symbology is only appearance use only and does not impact analysis. More info can be found here.
Raster rendering behavior
Raster data display decisions
Question | Analyze | Visualize
Ed_
