Table widget odd behavior - Dashboard
1335
02-10-2022 08:55 AM
JayJohnsonWashoeCounty
I have a SQL view that feeds a service, which ends up as an AGOL Item.
When I add this item to a dashboard I get a confusing behavior when in the table widget.
If I use the Table widget, the display is incorrect.  If I use the List widget I get the correct results.
The results as shown in the LIST above mimic exactly what I see in the Item's Data tab (and which is the correct data).
Any idea what is going on with the Table widget here?
The view was created by someone else and there are two outer joins in it - can this be an issue?
Jay
Washoe County GIS
KlaraSchmitt
Hello,
I'm sorry you're having issues. Based on the picture you've provided, I think you are referring to the table widget used in Map Viewer or perhaps, ArcGIS Dashboards. If so, you may find reposting this issue in one of those product-specific communities may get you a faster response as this community is specific to ArcGIS Hub and we do not work directly on the table widget you have shown.
ArcGIS Online: https://community.esri.com/t5/arcgis-online/ct-p/arcgis-online
ArcGIS Dashboards: https://community.esri.com/t5/arcgis-dashboards/ct-p/arcgis-dashboards
KlaraSchmitt
Hello,
Klara, Yes, thanks for pointing that out.  I've been doing a lot of work on HUB lately and guess I didn't realize I was still in "HUB space" when I posted that.  I'll re-post in Dashboard.
Jay
Washoe County GIS
