Straight Line on ArcScene after adding Z-coordinate
2139
5
04-21-2018 09:49 PM
GauravBhardwaj1
I'm trying to do space-time analysis on ArcScene. In doing so, I'm using Add XY data to input my tabular data. When I input X and Y values, I get a normal map in 2D, but when I add the third axis (time), it just gives me a straight line on ArcScene and X and Y values loose their significance. (Note: My time column has values in HHMMSS.SS format)
This is my data
This is my data
This is the ArcScene output I get after importing XYZ data
DanPatterson_Retired
If looks like your longitude and latitude are from a very limited range relative to the z
GauravBhardwaj1
Hi Dan,
I tried taking log of the time column but still getting a single line point values. Now my log_time ranges from 33-36 which is comparable to the latitude and longitude
XanderBakker
Esri Esteemed Contributor
I assume you have not defined a particular vertical coordina system for the data, right? In that case it will assume the same unit used for the X and Y values to be used for the Z values leading to unwanted results. You could create another field that expresses the time from the start time and use a different unit (minutes, hours days, depending on the range of time values). What is your use case for using time as Z axis? What do you want to visualize?
Normally time is used to visualize an animation of movement over time (in 2D or in 3D, if you have Z values)
GauravBhardwaj1
Yes, I'm visualizing space-time variation of my data in 3D. When i try to use my time field as Z-axis, it doesn't show up on ArcScene's 'Add XY Data'  as its not of integer form. This was the reason I was trying to convert the time to integer and then use it.
XanderBakker
