Set Label color to category value?
206
06-23-2024 08:24 PM
DavidGray1
New Contributor III
Hello Community;   It took awhile to find where this page is where one can post a question to the user community.
I am wanting to set the color of a label to the value that that variable contains in a graduated symbol color scheme for the data. Is this possible without fancy cryptic programming?    Thanks;    Dave
Tags (1)
DavidGray1
New Contributor III
Is this the right place to ask questions on using Pro
ChristopherCounsell
MVP Regular Contributor
No. I've moved it to the ArcGIS Pro community.
ChristopherCounsell
Don't view programming as 'cryptic'. It's more accessible than you think.
But yes, you can use Label Classes.
https://pro.arcgis.com/en/pro-app/latest/help/mapping/text/label-classes.htm
Add a label class then use the filtering on it for each value. This is typically used for different scale levels but if you have a few values for different colours it might not be too bad. As you get more values, the more classes you'll need, so using Arcade might be easier.
