"View DataTable" does not work for datasets that are based on a join
1817
06-04-2021 02:00 PM
JenniferSherry
Hello, I have noticed that since the updates to ArcGIS Hub were released, for at least two datasets on our Open Data/Hub site, the "view table" option no longer works.
https://open-data.bouldercolorado.gov/datasets/d7ad8e150c164c32ab1690658f3fa662_4/explore?location=4...
Source: https://maps.bouldercolorado.gov/arcgis2/rest/services/osmp/TrailsNEW/MapServer/4
https://open-data.bouldercolorado.gov/datasets/800684cdaf50432a988b1f3ee763a13a_3/explore?location=4...
Source: https://maps.bouldercolorado.gov/arcgis2/rest/services/osmp/Property/MapServer/3
I was able pinpoint that for these two data layers, published from our ArcGIS Server, each contains a join in the data.  Interestingly, the tables appear just fine in the AGOL items:
https://boulder.maps.arcgis.com/home/item.html?id=d7ad8e150c164c32ab1690658f3fa662#data
https://boulder.maps.arcgis.com/home/item.html?id=800684cdaf50432a988b1f3ee763a13a#data
I could probably resolve this by creating spatial views to publish the feature layers from, but I'm also thinking this is a bug that needs addressed.
Thanks in advance for any advice or helpl you can offer!
Jennifer
by Anonymous User
Not applicable
Thanks for reaching out, Jennifer. I'm not seeing any obvious reason why the tables aren't loading, so we will need to investigate further. I'll reach out if we need any further info.
JenniferSherry
I have an update, but we are still basically having the same issue.  I tried removing/unsharing the dataset from our Hub content libary and also removed public sharing.  When I reapplied the sharing that enables the item to be part of the Hub, I am able now able to see only the column names, but still not the attributes:
Any updates on why these tables (that are based on joins) are not showing up?
Thanks-
Jennifer
by Anonymous User
Not applicable
We're still investigating the cause and will be working on a fix that we expect to be out next week. I will report back if that timeline changes.
by Anonymous User
Not applicable
We've released an update today that should fix the reported issue, but in the course of QAing we discovered an additional bug with sorting. We're working on a fix and plan to release as soon as it's ready.
