Phantom items in Open Data Beta
2891
16
11-18-2016 07:10 AM
KevinDunlop
Occasional Contributor III
I am having an issue with Phantom items in the Open Data Beta.  Basically, it will create two records for the same item, one gets update and the other does not.  It happens when changing ownership and index number.  I am able to reproduce this problem by following steps:
1.  Create an Feature Layer in AGOL under first user (ex myUser).  I used URL of https://myOrg.com/arcgis/rest/services/myFolder/mySerice/MapServer/13 for example
2. Assign Feature Layer to a group(s).
3. Change ownership to a different user (ex myOrg)
4. In a new browser tab, update index in Open Data data manager
5. In previous AGOL tab, change layer index in URL.  Example change 13 to 7 so that it is now  https://myOrg.com/arcgis/rest/services/myFolder/mySerice/MapServer/7
6. In previous Open Data tab, update index in Open Data data manager
You show now have two records for the same layer but with different users each.  You can test this by deleting feature layer.  One of the records will disappear and the other will remain.  In addition, the remaining layer points to a broken URL.
I have been unable to remove these phantom item records no matter what I try.  Here is some screen shots on an example (Railroad).
Does anyone know how to remove these phantom items?   Thanks,
Kevin Dunlop
GIS Database Developer
Prince William County.
Tags (1)
KevinDunlop
Hi Courtney,
The site is private since we are still building it but here are the URL.
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/1e8289568fd94be1a870c9e8208b5741_2
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/6889ccda4a3447beaceadf8cb553f287_4
Please let me know if you need any additional information.
Kevin
CourtneyClaessens
Thank you Kevin, these have been removed.
by Anonymous User
Not applicable
I've also experienced problems with an orphan layer that I've ,unsuccessfully, tried to remove. After removing all share privileges and the Group share the layer continued to appear. Presently the layer appears 3 times , 2- orphans and 1 valid reference.
The orphan URLs are:
http://data.burnaby.ca/datasets/69aca4c2ac0f465e87cf94dea20abc4a_26
http://data.burnaby.ca/datasets/69aca4c2ac0f465e87cf94dea20abc4a_34
Terry.
CourtneyClaessens
Hi Terry,
We've removed these from the index.
Courtney
C_EHoward
How long should we expect to wait before unwanted/phantom datasets go away on their own? I have a couple more today even though I have unshared from open data. I know the index gets updated routinely but it may not be often enough based on all of the manual intervention your team has to do. And using the index buttons on the management page does not seem to do anything than generate a message that something is happening (but no moving icons as in the past).  thanks-
by Anonymous User
Not applicable
Hey Courtney,
Much better thank you.
Terry.
KevinDunlop
Hi Courtney,
We had to change several of services which caused many phantom items.  Can you remove:
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/13caaf8f329340f181c29044933173dd_6
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/1c71e4d6a7bf4db3b1dbccfd718dfcc4_1
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/262e7db2b3b44d44b7d22b509fd3495a_4
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/26e0c74d4fe845d7a5871c0747e6e74f_7
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/373c4b56843b46999a3cfdbfb96e546b_6
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/37afe6ccfdd84a61b1664dd6b53ba1ba_9
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/3f68fbc57b254a02b64f764ef382c627_0
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/409de103e95a4416a2fc984b7fef1b6a_5
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/437102c5c39848748bc88178d12a8186_2
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/529bd00516ea44fea2fc972304e02b42_0
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/589b7dd672d546d885d758863ee3beca_10
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/6339aa3ce01e4d249bd611917f86c0e7_2
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/6889ccda4a3447beaceadf8cb553f287_3
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/78fb6401d2d642dca948fe76f57aa590_3
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/7d0098c603bc407699f358a19e078571_10
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/8bedc966e5664949bb63ffe80cea7b30_1
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/8bedc966e5664949bb63ffe80cea7b30_17
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/972ebe3afc2d494bb7e5ad165dc643a6_5
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/97a9e95e439f465fbd8f980df3c94023_2
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/9991417de79143aba7d11a67de4247f8_4
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/ac728540b9454a2980873d9e478e0363_9
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/c392775c561842d796c248c350c14835_5
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/cc2376aa1b454b469386b7f355577e87_0
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/cde2c92964b44349b21a0682da5bcf2e_1
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/d0944abd75b2494f9f8321a2bf0fa43b_3
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/d77846fb52634227b77385c2a47f7a5a_7
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/e50871e73a304709a0c33019d25835d0_5
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/e53941719add435bbd1a36712f331841_2
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/e53941719add435bbd1a36712f331841_3
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/e9f0d72fe33e4ea6850cb10af07ca47f_13
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/f9e08998523d44e3bfebcf439e250fc8_12
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/f9ead7671f174ffea188914c6fba8e50_2
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/fc90fa6cf52f44c09084e82ee50acc8d_6
In addition, I have two records with the same URL and attributes.  I am not sure how that happened.
http://gisbeta.pwcgov.opendata.arcgis.com/datasets/db9f8761dad340c799112d37b56024de_11
