LAS Dataset toolbar not reading .lasd in ArcGIS 10.5
3229
9
04-24-2017 02:07 PM
LindaHowie
I created an LAS dataset in ArcGIS 10.1 on one machine and was able to use the LAS Dataset toolbar to create profiles etc. I'm now working with the same map and files on a different machine running ArcGIS 10.5 and the LAS Dataset toolbar will not recognize the .lasd layer. The dropdown menu is grayed out even though the dataset was added to the map and present in the ToC. I tried creating a new LAS Dataset from the same LAS tiles and made sure statistics were calculated, but I still cannot get the toolbar to recognize the .lasd layer. I have all the necessary extensions authorized. Is this a problem with the v. 10.5? Thanks to anyone who can help.
DanPatterson_Retired
What license level is on the 10.5 machine? and if basic, then make sure that you have toggled on the 3D analyst
  • ArcGIS Desktop Basic: Requires 3D Analyst   ****
  • ArcGIS Desktop Standard: Requires 3D Analyst
  • ArcGIS Desktop Advanced: Requires 3D Analyst
LindaHowie
Hi there. I have an Advanced license with 3D analyst licensed and enabled.
check the caveat's in the 10.5 topic an-overview-of-displaying-las-datasets...  tracking down what changed and where would require some work
LindaHowie
Ok, will do. Thanks!
LindaHowie
I guess I could also note that the LAS Dataset will display as a pointcloud in ArcMap, I just can't perform any operations on it with the toolbar.
The only other reference I found using 'las toolbar' as a search on geonet, linked me to a comment I made about 3D and a basic license... which you nixed... and another about a format difference in the las data... I will try to track it down again.
EDIT
https://community.esri.com/message/654963-re-questions-about-las-14-support-and-las-data-not-display...
LindaHowie
Thanks a lot. I'll take a look at that link and see what I can do. Appreciate the help.
LindaHowie
Got it sorted out. Thanks again for your help!
UCTGeology
Hi there, could I ask how you managed to resolve this? I'm having the same issue
