Hub indexer using invalid queries
1294
11-06-2020 01:38 PM
GJY
I noticed that several datasets referenced in our Hub site do not have up-to-date data downloads.  I checked the API for one and saw that there was an error.  See here: https://opendata.arcgis.com/api/v3/datasets/923cb3294384488e8a4ffbeb3b8f6cb2_32/downloads?spatialRef...
The query that it is trying to execute references a range of OBJECTID's that does not actually exist in the data, which produces an error.
https://ws.lioservices.lrc.gov.on.ca/arcgis1071a/rest/services/LIO_OPEN_DATA/LIO_Open01/MapServer/32...
It appears that the cache process has been running for 8 days already... I guess the process just hangs there after this failure?  What is causing this to happen and can it be fixed?
GJY
Long time responding here, but this query seems to be working correctly now.  I will report back if we encounter others.  Thanks.
ThomasHervey1
Esri Alum
Sorry to hear about this issue. Are you still experiencing the issue? The example that you provided shows no errors in the history and the caching job only started today 11/9/2020. If you see a problematic query again, can you please respond to this thread?
GJY
