DCAT Configuration Tool?
2538
04-28-2021 11:29 AM
KristenWobbe1
Hello!
We are trying to set up DCAT-JSON for our Hub site on our TEST-AGOL instance.
We have followed the document Esri provided and set our “bureauCode” and “programCode”: https://doc.arcgis.com/en/hub/content/federate-data-with-external-catalogs.htm
However, when I try to browse to the DCAT “data.json” for our test Hub site it does not work:
 https://blm-gis-open-data-blmtest.hub.arcgis.com/data.json
 It appears the "site" and "content" need to be shared to the public to test this.
Are there any other settings we need to have configured for our Hub site to work?
Thanks in advance for any info you could provide or point me to.
KatelynThompson
Hi Kristen, public content will appear in the dcat feed automatically.
KatelynThompson
Hi Kristen,
The reason this workflow might not be working is because the site you link to points to a legacy site which is no longer supported by ArcGIS Hub as of September 8, 2020. Instructions for migrating your site are available here.
KristenWobbe1
No we built this on the new Hub site. I think you are just confused by the name we gave  the Hub App for our site. Thanks for pointing me to the blog to verify. My question is does the content need to be shared to the public to show up in the Data.json, and/or does the site itself has to be public too, or just the data published to Hub?
KatelynThompson
