ArcGIS Online Hub Gallery Card
702
06-07-2023 11:50 AM
PaulTHEDUDELang
New Contributor III
Hello
Using a gallery card, with thumbnail images and descriptions from content pages for each initiatives.  All the cards on the gallery have a white background, is it possible to have this transparent so i could display an image underneath???
Thanks
Paul
David_McRitchie
Hey Paul on the Gallery cards you can only have these as white.
As a workaround you can use a text box to give the appearance of a card and then use the HTML to edit the background.
Hope that helps,
David
Esri UK -Technical Support Analyst
David_McRitchie
Hope that helps,
David
PaulTHEDUDELang
New Contributor III
 David
Thanks for the reply.   That's exactly what we moved on to but that also has it draw back.
Paul
