Last week I came across something in the arcgis HUB of our organization that I had not noticed before, but which can have very unpleasant consequences.
This involves the following: In the HUB, pages can be connected to the main page via the configuration menu, after which they can be formatted and configurated. In the old situation, these pages could then be disconnected again when they were (temporarily) no longer needed. In the current situation this is no longer possible.
The disconnect option seems to be changed to a delete option, which still disconnect the page from the main site but at the same time deletes the page item and its layout/content/groups in its entirety. I don't think that is the intention and in our case it would be very dissapointing if this happened (accidentally). I also noticed that for our "older" pages the old option ("remove page from website") is still available. For the more recent pages, only “delete page” can be selected. See also the attachments for what it looks like.
Update: after some more research I found that pages that have been cloned from already existing page are added to the HUB with the option "remove page from website". When a page is made from scratch by adding a new page, it can only be removed completely.
It would be very nice if the option "remove page from website" will be available in all cases!
@ChristaKemperman1 Following up on this post.
In 2025, Hub updated how Pages are managed to make it easier for the workflow you mention.
Hub Pages now work like any other content Item shared in a Hub catalog . To remove a page from a site, you just remove that page from one of the groups in the Hub catalog.
Have you tried this new workflow?
