Unlock expanded functionality in ArcGIS Hub: Upgrade your catalog today
226
Tuesday
Labels (3)
JoeVTavano
ArcGIS Hub site editors can now unlock expanded functionality in their site content catalog. When signed in to a site workspace, look for the Upgrade catalog notice on the Catalog > Content pane. Select Upgrade to upgrade your site's catalog for added functionality.
Upgrade catalog noticeUpgrade catalog notice
When you upgrade, your existing content catalog is preserved and you won't lose anything. Best of all, this new catalog functionality gives you more control and granularity to build custom catalogs and share your content as you see fit.
Upgrading means that users who have opted out of workspaces will not be able to use the classic editing interface, including the following functionality for a site: Classic groups manager, Classic feeds configuration, Classic content library, and Classic feedback.
Benefits of upgrading
Configurable catalogs are a powerful way to organize your content. Before upgrading, the classic content library has limited customization options. Upgraded catalogs offer greater control, better organization, real-time customization, and future-proof design. Learn more.
Create custom collections
The ability to create custom collections is the big benefit Hub site editors and all site visitors will experience with the catalog migration. Custom collections allow you to organize content into distinct subsets for easier browsing and discovery. Previously, you were able to rename, reorder, show, or hide your collections.
Now, you can do so much more! In the Catalog configuration window find Configure collections, where you can create and modify collections using a wide range of parameters:
  • Manual selection
  • Created date
  • Modified date
  • Type
  • Sharing
  • Categories
  • Tags
Catalog parametersCatalog parameters
Each parameter will offer different criteria and selectable options. The image below shows options for Type.
Options for Type parameterOptions for Type parameter
You can also modify collections that existed prior to upgrading. Previously, default collections could only be renamed. Now you will have the ability to configure those collections to better suit your needs.
Be sure to select Save changes (at the bottom of the Catalog configuration window) when finished to save all your custom settings for the content catalog. Upgrade your site catalog today to see these benefits and have greater control over customizing catalogs of curated content.
Catalog functionality matrix
Basic
Premium
Unmigrated Catalogs
Collections per catalog
≤4 collections
≤10 collections
4 default collections
Modify the position and visibility of collections?
All collections
All collections
All collections
Remove collections?
All collections
All collections
Default collections cannot be removed
Edit collection details?
Name, filters
Name, filters
Name only
Filters per collection
1 filter
Any number of filters
Default collection filters cannot be changed
Not ready to upgrade quite yet? No problem. Just select Cancel on the upgrade notification. You can upgrade at any time. Just return to your site’s content catalog to find the Upgrade catalog button.
Upgrade catalog buttonUpgrade catalog button
Contributors
About the Author
Joe Tavano is a Product Engineer at Esri, working on ArcGIS Hub.
