Can't Add Capabilities in 10.2 after much success with 10.1.1
1591
02-25-2014 04:07 PM
WilliamSands
We've recently upgraded to ArcGIS for Windows Mobile 10.2 in order to get around the low resolution camera bug from 10.1.
The problem is that the custom extension we use can't be added within Mobile Project Center. The "Add" button in the Capabilities tab is greyed out. The extension has been rebuilt for 10.2, but the greyed out Add option may not be related to the actual extension itself.
ESRI's instructions here have been followed correctly unless there is a change of location from 10.1?
This problem exists on all of our PC's.
Has anyone else successfully added capabilities in 10.2 that were working fine in 10.1?
Thanks
WilliamSands
After much diagnosis, it looks like the developer updated the .dll for 10.2 incorrectly! Testing with Esri's own samples of capabilities helped us uncover where the error lay. Problem solved.
WilliamSands
