ArcGIS Maps for Teams uses incorrect URLs when opening search results in the Viewer
1041
7
02-07-2023 02:18 PM
RobertSistersonYCC
When connected to our ArcGIS Enterprise (10.8.1) environment, opening search results from Chat will fail (see below for the error message). When I Open in browser, it uses a malformed URL which I can correct as follows (I've highlighted the incorrect and corrected part of the URL):
  • FAIL - https://{Portal DNS}/arcgis/apps/mapviewer/index.html?webmap={OID}&arcgis-auth-origin=https%3A%2F%2Farcgis4teams.arcgis.com&arcgis-auth-portal=https%3A%2F%2F{Portal DNS}%2Farcgis%2Fsharing%2Frest
  • SUCCEED - https://{Portal DNS}/arcgis/home/webmap/viewer.html?webmap={OID}&arcgis-auth-origin=https%3A%2F%2Farcgis4teams.arcgis.com&arcgis-auth-portal=https%3A%2F%2F{Portal DNS}%2Farcgis%2Fsharing%2Frest
SeanKMcGinnis
Hi @RobertSistersonYCC - that does seem like an issue. Could you please open a support ticket on that?
-sean
Sean McGinnis - ArcGIS for Microsoft 365 Product Manager
RobertSistersonYCC
Hi @SeanKMcGinnis - I've raised case # 03267366 with Esri Australia.
SeanKMcGinnis
FYI - @SebastianSaballett
-sean
SebastianSaballett
Thank you Sean! And @RobertSistersonYCC thank you for providing the URL, I will go ahead and take a look to verify and analyze this issue!
AndyIngall
I am getting the same issue, has there been any resolution, or are there specific versions of enterprise that ArcGIS for Teams works with...  @SeanKMcGinnis @RobertSistersonYCC
SebastianSaballett
Are you working with a specific ArcGIS item? Previously we had looked into the issue pertaining to a web map viewer item. Could you provide some more context on the item you are receiving this same issue? Is it the web map viewer as well or another ArcGIS item?
AndyIngall
It appears to be all types of service with the exception of WMS.  I have tried Map Service, Web Map, Feature Service and Dashboard.  I am getting the same error on each... @SebastianSaballett @SeanKMcGinnis
