Utilization and Requests while using ArcGIS Integration with Teams
Had a question about the utilization of map and feature layers while sharing a map using the Teams integration. While on a test call with one other person I noticed that a brand new map with only the two of us and Teams looking at it jumped from 0 views to 100 ~ 30 minutes. This scales with additional people, as we added…
Honour usage sharing from ArcGIS Online (or set as opt-in)
When using ArcGIS for Teams (and any other Esri software), as a company, we prefer to not share usage information with Esri. In ArcGIS Online and ArcGIS Pro this can be disabled. When using ArcGIS for Teams to share content in a Teams meeting, sharing usage information with Esri is enabled by default. Even when a user is…
Any action on BUG-000153695?
This bug, BUG-000153695, https://support.esri.com/en-us/bug/unable-to-log-in-to-arcgis-for-teams-with-arcgis-enterp-bug-000153695, is causing some headaches. It's status is "In Product Plan." Does anyone have an idea as to when or if it might be fixed? It seems like an epic showstopper. Thanks!
ArcGIS for Teams: 2025.2.2 Changelog
ArcGIS for Teams 2025.2 received a minor update on August 29, 2025, introducing the Link unfurling feature. This enhancement enables users with ArcGIS for Teams to generate adaptive cards from links to various compatible ArcGIS items. When an ArcGIS item URL is entered into the message prompt, an item card is automatically…
Does ArcGIS Teams work with GCC-High?
Hello, Our IT team is wondering about the configuration of ArcGIS Teams to determine if we can get it to work in our systems. One of the questions that they have is whether it can work with GCC-High. Any detailed information or documentation you can provide about this will be helpful. Thanks!
ArcGIS for Teams, Web Maps sketches break Mapping Applications
I met Sebastian and Chuck at UC2025 and they were outstanding at explaining A4T, implementation and usage. We want to roll this out to users, but I think I have run into a problem. When I create a sketch in A4T on a Web Map, the linked Portal map (Web Mapping Application) fails to fully load, no frame or layers, just the…
ArcGIS for Teams assistant (beta)
What is the ArcGIS for Teams assistant (beta)? The Assistant in ArcGIS for Teams will enable conversational search, using an LLM, to find items within ArcGIS Online. The assistant can be used to search in your content, the Organization, in Groups or for public items. Using natural language in the chat, you can Search and…
ArcGIS Web Experience Builder support in ArcGIS for Teams
Are their plans to support ArcGIS Web Experience Builder apps to be added as tabs in channels via the ArcGIS for Teams Add-in? We've just been through quite a long process to get the ArcGIS for Teams add-in approved and enabled by our IT team, only to discover that ArcGIS Web Experience Apps do not work in the app. This is…
Autopopulate ArcGIS Portal URL in Teams Sign in page
Hi there, Is there anyway to autopopulate the ArcGIS Portal URL in ArcGIS for Teams so that if we push it out to all our users they do not have to do it individually? We want them all to sign in to our enterprise portal by default. Automatically signing them in would be even better. We have SSO via SAML in Microsoft Entra…
Collaborate with maps using ArcGIS for Teams
Share maps in Microsoft Teams through the chat or a call and allow others to annotate. This video tutorial by Heather Smith and Zoya Domashnev demonstrates how to use ArcGIS for Teams to collaborate spatially. To learn more, visit the ArcGIS for Teams - Sketch, annotate, and collaborate ArcGIS blog article and the ArcGIS…
Unable to download from source data ArcGIS dashboard on MS Teams
Hello Everyone. I'm trying to download the source data from ArcGIS dashboard plugin for MS Teams and the button goes to the page arcgis.com/apps/dashboards/download and nothing happens. When I open the dashboard on the browser, the button works perfectly. But on MS Teams the issue persists. I checked the permissions data…
Error with ArcGIS for teams Pluggin, is not there and gives an error trying to add it again
Hello, I have copilot in arcgis for teams and also i have ArcGIS for teams installed. it was working but for some reason the pluggin disappear. And when I try to add it again it gives me an error " there was an issue adding it. Contact your IT Admin for Help. Any idea? Thanks, DLL
Looking for a method to open a specific item when a keyword is entered in Teams chat.
Hello: I am looking to find a method to open a specific item when a keyword is entered. Rather than getting. "Where would you like to search? What content are you looking for?" I would like to open the specific item directly.(of course, understanding that there may be a login, but open the item directly after login). I…
Teams Opens Item Detail Page, Not Map or App
Hi: I’m not sure what I’m doing wrong: I’ve installed the ArcGIS for Teams app, connected it to Enterprise and am able to search for content. The issue I’m having is when I select from the chat, either a map or app to post, the viewer page displays the thumbnail, and when I click “Open in browser”, I’m taken to the map /…
Search for ArcGIS content with ArcGIS for Teams
This article was last updated on 10/03/2024 Note: The Microsoft Copilot is currently not supported in ArcGIS, and is beta preview only. Please reach out to the ArcGIS for Teams product engineers in Esri community for questions and concerns. There are two new ways you can search for ArcGIS content with ArcGIS for Teams.…
Adding ArcGIS for Teams tab Programmatically with URL Parameters
We're using PowerAutomate to create new teams in Microsoft Teams and automatically adding channel tabs, including tabs containing ArcGIS Dashboards. We've added ArcGIS content in the past, adding the tabs as 'Websites', however, the new teams appears to block the oAuth process - forcing the tab to be opened in a browser…
Adding Enterprise App to ArcGIS for Teams Channel
Hi! I have an app within ArcGIS Enterprise (11.1) which is shared to our org. If I share / post this app within a Teams channel, could anyone within the company without an Enterprise license be able to see the map and associated pop-up data? Thanks!
Live Share Not Working Properly
I'm trying out the new Live Share feature in ArcGIS for Teams. Pretty cool concept! Unfortunately, I'm running into a couple issues: * When I add the New Live Share tab, I'm the only one that can see which content item was added. Here's what I see on the ArcGIS tab: Here's what other members of the meeting see: 2. Attempts…
Adding ArcGIS Tab to a Team to Share Dashboard
I have had a Dashboard shared to a Team for a while using the Website tab via a URL, lately we have started encountering this error and learned that this style of tab will be getting retired in the spring. Someone had mentioned using the ArcGIS for Teams set up and I'm trying to add this dashboard to the Team that way,…
ArcGIS for Teams Viewer Tab Flickering
I posted a Web Mapping Application from our ArcGIS Online into ArcGIS for Teams. I used the built-in search chat tool to search for it and post it. When I click Open on the post, it opens the Viewer window and tries to load the map. I can see the app header and the map tries to load, but immediately flickers white. It…
ArcGIS for Teams. Automatically update from excel spreadsheet
I have an AGOL group that I share access to with colleagues from other agencies. We are working on a habitat map based on a spreadsheet we share. We'd like to put the spreadsheet online, so each of us can update data as needed, but want that spreadsheet to link directly to a feature layer which is on the map we're…
ArcGIS Maps for Teams uses incorrect URLs when opening search results in the Viewer
When connected to our ArcGIS Enterprise (10.8.1) environment, opening search results from Chat will fail (see below for the error message). When I Open in browser, it uses a malformed URL which I can correct as follows (I've highlighted the incorrect and corrected part of the URL): * FAIL…
Unable to sign in with a different AGOL account to ArcGIS for Teams
Hi Team, I logged in to ArcGIS for Maps with my AGOL account. When wanting to try to log in with a different AGOL account, I signed out of ArcGIS (under options -> Sign out of ArcGIS). Upon trying to sign in to ArcGIS again, it automatically picked my credentials and did not give me the chance to enter a different one. I…
ArcGIS for Teams card shows a blank space
Some people see a blank space in ArcGIS for Teams instead of content coming from our ArcGIS Enterprise portal. It doesn't happen for other users. The user can login to ArcGIS Enterprise, but the content shared by another user (open to all org users) doesn't show up. Has anyone seen this issue?
Advantages to using ArcGIS for Teams?
Can somebody explain to me what the advantages are to using ArcGIS for Teams? I'm not sure if I'm understanding the utility. If I "embed" a map/app/dashboard/etc. into Teams, can all members of the Team see that content - even if they don't have an ArcGIS Online login? That would have tremendous utility if that is the…
