Change log and updates (May-2026) - ArcGIS for SharePoint- v 2026.1.0.0 Update 1
No Update Required If you already have the 2026.1.0.0 version of ArcGIS for SharePoint installed from the SharePoint Store or Microsoft Store, there’s no need to install a new version of the app. Simply reload or refresh your browser, and the latest enhancements will automatically become available in your existing ArcGIS…
Change log and updates (April - 2026) - ArcGIS for SharePoint- v 2026.1.0.0
Update (05-06/2026): Added information regarding local DNS connectivity enhancements for ArcGIS for SharePoint. Edit SharePoint data directly on the map One of the most requested capabilities is finally here: full editing support for SharePoint lists and document libraries. You can now: * Edit geometry (move points,…
Add ArcGis layer - Credentials lost?
In several SharePoint sites, the ArcGIS for SharePoint component has been added with the goal of including, in each site, an ArcGIS layer that displays the GIS data specific to each project. The usual process is as follows: The person responsible for editing the page accesses the SharePoint site. They insert the ArcGIS for…
Geoenable button missing from some lists
We have a tenant with multiple sites. We have added the ArcGIS for SharePoint (latest version) to two different sites. But when we create a new list, one site shows the Geoenable button, but the other doesn't. It's unclear whats different between them. The user is a SiteOwner for both sites.
How to Integrate ArcGIS Enterprise (Intranet-Only) with SharePoint Online?
One of our clients is planning an integration between ArcGIS Enterprise (Portal deployed in an intranet-only environment) and SharePoint Online. From a network and security standpoint, the requirement is to allow outbound access from ArcGIS Enterprise to specific SharePoint Online URLs/endpoints, while restricting inbound…
413 RequestEntityTooLarge - Automating EXIF metadata extraction workflow
Hello, We have enabled the flow "Automating the EXIF metadata extraction workflow" in a Sharepoint library to extract EXIF data, but when it runs on files larger than 10 MB, the following error appears: “413 - RequestEntityTooLarge.” Is there any way to solve this issue? Thanks in advance
Maps fail when using Chrome 142+ and local Enterprise
Version: 2025.3.1.0. Due to an update of Chrome (Edge) local network access is no longer allowed per default: Adapting your website for new Local Network Access restrictions in Chrome This change conflicts with our SharePoint configuration: SharePoint online + local Enterprise. The error: "The specified ArcGIS Online (or…
Update Required: Fix for Disabled Toggle in ArcGIS for SharePoint
ArcGIS for SharePoint Notice We’re aware of an issue where the Extract EXIF Data and Geoenablement feature toggles in ArcGIS for SharePoint remain disabled (“off”), even when all required permissions are granted and users hold a valid premium Power Automate license. After investigation, we’ve identified that this behavior…
Configuring newest release: 2025.3.0
We’ve been testing ArcGIS for SharePoint to access documents from a map using geotags, either by keywords or coordinates. After deploying the latest release, version 2025.3.0, we noticed that the pop-up feature no longer displays the geotagged SharePoint items. The SharePoint document correctly recognizes the geotag in the…
Is there a way to programatically add layers to the sharepoint map or open a portal map?
Hi there, We want to deploy an ArcGIS SharePoint page to every SharePoint project workspace that our project management system generates. To do so I want to also create a group, templated map and app in our Portal, then link the Portal map to the SharePoint map. This way our GIS specialists can add layers to the map in…
Arcgis Sharepoint smbology rotation by attribute
In Sharepoint for ArcGIS, I'm having trouble populating the attribute dropdown for varying symbology by attribute. When connecting to a sharepoint photo library with a prepopulated field for the direction of rotation, the atrribute dropdown in the map webpart does not recognize any sharepoint fields when the values are…
ArcGIS online map not staying oriented in sharepoint
I am uploading a online map onto my groups website on sharepoint. When I open the map in AGOL, it opens up in the correct orientation I need; however, when uploaded to sharepoint, it orientates north. Is there anyway to prevent this from happening?
Change log and updates (October - 2025)- ArcGIS for SharePoint- v 2025.3.0.0
We’re excited to share some big news with you – our app has a brand-new release this month! 🎉 This update brings powerful new capabilities designed to make your Geoenablement workflows smoother, smarter, and more flexible than ever before. Whether you’re tagging documents, searching spatially, or automating repetitive…
Time slider in ArcGIS for SharePoint not updating with new photos despite auto-refresh enabled
Hello, Our organization is using ArcGIS for SharePoint to display photos of construction projects based on their geographic coordinates. In one of the layers, we enabled the “Enable time animation” option using the “Date Time Original” field, which causes a time slider to appear at the bottom of the map. In that same…
Support for Item-Level Permissions in SharePoint Document Libraries
Currently, ArcGIS for SharePoint applies permissions at the document library level, which limits the ability to manage access to individual files or folders within a library. In many enterprise scenarios, especially those involving sensitive geospatial data, it's crucial to enforce item-level permissions to ensure that…
Edit button missing due to folder-level write permissions not being recognized.
Hello Our organization is using ArcGIS for SharePoint to display photos of construction projects based on their geographic coordinates. Users are able to modify these coordinates directly through the SharePoint grid. However, when they select the “Edit Locations” option from the menu, the edit button (pencil icon) does not…
Relocating Photos in ArcGIS for SharePoint
Hello, In our organization, we are using ArcGIS for SharePoint to geolocate photographs stored in a SharePoint library using their coordinates. Sometimes, we need to modify the location of these photos, and we would like to relocate the point directly from ArcGIS for SharePoint. The process we currently follow is to go to…
Geocoded SharePoint data displayed dynamically in ArcGIS online map
Hello, I've got some flows running that give me a SharePoint list with geocoded records, and a .csv file with geocoded records. What I would like to do is use one of those as a data source to create a map that updates each time the list or the .csv file updates, and displays those records on a map. Ideally this would be…
Change log and updates (June - 2025)- ArcGIS for SharePoint- v 2025.2.0.0
We’re excited to share some new features and enhancements that are now live in ArcGIS for SharePoint app. These updates are designed to improve your workflows, based on feedback from our users and our commitment to continuous improvement. * The Editor tool allows you to create, edit, or delete features on your accessible…
New features are not available, and the navigation buttons are empty boxes in ArcGIS SharePoint
I am using ArcGIS for SharePoint and created my first web part. I noticed that my layout does not look quite right. Many of the buttons are blank squares and I don't seem to have the newer capabilities I have read about (like 'Add Document Urls'). Does anyone have insight into this? Is it because of my organization's…
Managing ArcGIS Pro in Sharepoint | Unable to Add an Additional File Geodatabase & Reshare to SharePoint
I save two (2) files into sharepoint. A.aprx (an ArcGIS project file) A.ppkx (a Packaged Project file) Each one opens well. But I want to add a new file geodatabase (and did) to A.aprx. I saved it. I then reshared over the existing A.ppkx (a Packaged Project file). No error messages. But when I open it. the newly added…
ArcGIS for SharePoint - Changing the view to reflect new data
Hi I'm using a SharePoint Web Part connected to a Sharepoint List to display a location map using ArcGIS. The user can select a base location and relevant map data for that location will be transferred into the SharePoint list, overwriting any previous data. this is being done through Power automate. all working fine…
Change log and updates (March 2025)- ArcGIS for SharePoint- v 2025.1.0.0
New features and enhancements: Automate your EXIF data extraction workflow by setting up a Power Automate flow Using this new feature, ArcGIS for SharePoint users will now be able to automate the extraction of EXIF metadata embedded in image files. We've posted a new blog on Esri Community explaining how to set up the…
Integrate your Geotagged Documents Seamlessly into ArcGIS with this new ArcGIS for SharePoint Feature
Why This Feature Matters For years, users have been asking for a more effective way to manage geotagged documents in SharePoint. Geotagging is crucial for many industries such as construction, real estate, urban planning, and environmental science, where the capability of accessing documents tagged to features on the map…
Introducing EXIF Metadata Extraction and Workflow Automation using ArcGIS for SharePoint
In today’s digital age, managing image files effectively is crucial for businesses and organizations that work with a large volume of visual content. One of the key pieces of information embedded in every image file is Exchangeable Image File Format (EXIF) metadata, which includes details such as GPS coordinates, the date…
