ArcGIS for SharePoint Questions
79
1.6M
723
Open | Good day to all...I'm a SP Admin/Dev and installed the ArcGIS SharePoint Webpart in our MS Tenant.Did a quick POC whe... by BrianLabelleSMLP Emerging Contributor 1 12 | 1 | 12 | |
Open | What3words have received some requests to plot SharePoint files that have only a what3words field to the ArcGIS for S... by manuciao Occasional Contributor 0 0 | 0 | 0 | |
Open | The Web Part Connectivity is very help feature and yet it is only available to on-prem SharePoint client as describe ... by WilliamWang Regular Contributor 1 1 | 1 | 1 | |
Open | ArcGIS map for sharepoint does not customize the display of pop-up windows.The idea would be to have button to rearra... by AmélieHERVE Occasional Contributor 3 1 | 3 | 1 | |
Open | Suggestion for improvement: Style toolWhen points of different layers have the same coordinates, the only way to see ... by AmélieHERVE Occasional Contributor 3 1 | 3 | 1 | |
Open | It would be very use to have a round trip function from a SharePoint list to ArcGIS Webpart to Collector and then bac... by HeidiClark Emerging Contributor 1 1 | 1 | 1 | |
Open | Please consider adding support for enterprise authentication for ArcGIS for SharePoint workflows. Product documentati... by GrzegorzGłowacki Emerging Contributor 4 1 | 4 | 1 | |
Open | Within a project I would like to make some maps available to view by the client but not publicly visible.Allow Extern... by JoeNunn Frequent Contributor 6 2 | 6 | 2 | |
Open | Provide a better message when users have the older versions of an App installed and the code is no longer available. ... by CDavis Emerging Contributor 0 1 | 0 | 1 | |
Open | Currently Esri Maps for SharePoint requires you to log in to one particular portal that has been configured for the S... by NickMiller3 Deactivated User 4 3 | 4 | 3 | |
With SharePoint Online, in version 3.0.1 there was a functionality of persisted credentials, but in version 4.0, this... by AndreaHuber Deactivated User 2 0 | 2 | 0 | ||
Here are a few enhancements for the extensibilty framework for SharePoint: Open the SharePointListLayer object so pro... by AndrewChapkowski Esri Regular Contributor 3 1 | 3 | 1 | ||
Open | ARC GIS for SharePoint is a great tool for display of geolocated SharePoint data and spatial analysis across an enter... by DanielGnatz Deactivated User 13 1 | 13 | 1 | |
It can be quite an effort to search documents such as "all CP work orders completed in past five years for distributi... by JeffreyChen1 Deactivated User 14 0 | 14 | 0 |
Idea Submission Guidelines
