When will ArcGIS map be enabled in Power BI embedded and publish to web?
5426
11
05-14-2018 10:31 PM
vishnusuresh
ArcGIS map is great to use and is way better than the Bing map in Power BI, But it is not enabled for both embbeded power BI reports and publish to web reports.
Do you guys have a timeline for this feature?
Tags (1)
JonEmch
As of January 2021, Publish to web is officially supported:
https://doc.arcgis.com/en/power-bi/design/publish-to-web.htm
Please let me know if you have any questions!
Keep on keeping on!
TonyGaul
Hello.  Can someone please provide an update on this?
JonEmch
Keep on keeping on!
MAURICIOCASTRO1
I see no reason to block on PowerBI Embedded, as we still don't give an open access to everyone.
JonEmch
Keep on keeping on!
JonEmch
Hello all,
   At this point in time, embed to web has not been enabled for the ArcGIS Maps for PowerBI visual. We have logged an enhancement on this ENH-000130489: Add Publish to Web support to ArcGIS Maps for PowerBI visualizer in PowerBI Online, which has the current status of In product plan.
   While I am unable to comment as to when this will be resolved, I am able to say that the product team is very much aware of this limitation, and is working diligently with Microsoft on a resolution. If you are able to do so, I would encourage you to log a case with Esri Tech support to add your account to this enhancement.
Keep on keeping on!
BilelKhelil
Bonjour j'ai voulu mettre mon rapport sur le share point mais vos carte ne marchent pas pourquoi ?? Comment faire ???
JonEmch
Hi there! Would you mind re posting this as its own question?? How are you trying to add data to your cards?
Keep on keeping on!
BilelKhelil
Bonjour, merci pour votre réponse voici ce que la carte me donne comme problème, avez vous une solution ?
Je ne sais pas comment résoudre ce problème
JonEmch
Hey there,
Recently the way ArcGIS for PowerBI works with web embedding has changed, reports must now conform to the prerequisites listed here:
https://doc.arcgis.com/fr/power-bi/design/publish-to-web.htm (in French!)
Once you fulfil the requirements, your report should work again.
Keep on keeping on!
