Replicating a Spotfire case when query to a PowerBI New Column DAX Expression (switch case)
518
06-14-2022 08:14 AM
DhrumilPareshPatel
I am migrating a Spotfire Report to a PowerBI Report. For one of the columns, I have a Spotfire case when query that I want to convert to a switch case DAX Expression. I started out and I think I am good with the initial part of the query but am not sure how to build the rest of the query. Here are the details:
Spotfire case when query:
CASE  WHEN (
 [RefPointGroupCap] is not null) OR (
 [MortgageGroupCap] is not null) OR (
 [MPBGroupCap] is not null) OR (
 [NCBGroupCap] is not null) OR (
 [SRCGroupCap] is not null) THEN
     "Y"
        & (if([RefPointGroupCap] is null,""," / " & [RefPointGroupCap]))
        & (If([MortgageGroupCap] is null,""," / " & [MortgageGroupCap]))
        & (If([MPBGroupCap] is null,""," / " & [MPBGroupCap]))
        & (If([NCBGroupCap] is null,""," / " & [NCBGroupCap]))
        & (If([SRCGroupCap] is null,""," / " & [SRCGroupCap]))
WHEN (
 [RefPointGroupCap] is null) and (
 [MortgageGroupCap] is null) and (
 [MPBGroupCap] is null) and (
 [NCBGroupCap] is null) and (
 [SRCGroupCap] is null) THEN "N"
END
The switch case query I built half way:
Column=
SWITCH (
TRUE (),
NOT(ISBLANK('F22_New_Cumulative_export (2)'[RefPointGroupCap])) ||
NOT(ISBLANK('F22_New_Cumulative_export (2)'[MortgageGroupCap])) ||
NOT(ISBLANK('F22_New_Cumulative_export (2)'[MPBGroupCap])) ||
NOT(ISBLANK('F22_New_Cumulative_export (2)'[NCBGroupCap])) ||
NOT(ISBLANK('F22_New_Cumulative_export (2)'[SRCGroupCap])) ,
"Y" &&
(IF(ISBLANK('F22_New_Cumulative_export (2)'[RefPointGroupCap]), BLANK(), " / " & 'F22_New_Cumulative_export (2)'[RefPointGroupCap]) &&
(IF(ISBLANK('F22_New_Cumulative_export (2)'[MortgageGroupCap]), BLANK(), " / " & 'F22_New_Cumulative_export (2)'[MortgageGroupCap]) &&
(IF(ISBLANK('F22_New_Cumulative_export (2)'[MPBGroupCap]), BLANK(), " / " & 'F22_New_Cumulative_export (2)'[MPBGroupCap]) &&
(IF(ISBLANK('F22_New_Cumulative_export (2)'[NCBGroupCap]), BLANK(), " / " & 'F22_New_Cumulative_export (2)'[NCBGroupCap]) &&
(IF(ISBLANK('F22_New_Cumulative_export (2)'[SRCGroupCap]), BLANK(), " / " & 'F22_New_Cumulative_export (2)'[SRCGroupCap]),
ISBLANK('F22_New_Cumulative_export (2)'[RefPointGroupCap]) ||
ISBLANK('F22_New_Cumulative_export (2)'[MortgageGroupCap]) ||
ISBLANK('F22_New_Cumulative_export (2)'[MPBGroupCap]) ||
ISBLANK('F22_New_Cumulative_export (2)'[NCBGroupCap]) ||
"N"
Let me know if you need any more information, thanks for the help!
