Reference layers not filtering underlying data
593
12-07-2022 08:16 AM
Nawaaz
Hi all
I have some data points (by co-ordinates) plotted on my map. I have then imported a reference layer, and have made it an active layer- however when I try to select anywhere on the reference layer with the point select, the underlying data is not filtered. It highlights the section from the reference layer that I have selected but the number of points within the shape area is not filtered. I have selected 'interact with power bi visuals'. Strangely, it filters correctly when i use the rectangle select to choose anywhere within a reference layer section.
Has anybody come across this issue before? It seems like a bug with ARCGIS. Thanks
