Power BI Visual looses all settings
7457
22
05-20-2020 09:06 AM
DavidCresp
The Esri Map visual in Power BI is not saving settings. I set everything up for a boundary map based on one country and it is all fine. Go to another tab and back again and all settings have been lost. This has not been an issue before and seems to be an issue since the May edition of Power BI. It seems that the bug reported here is back again. https://community.powerbi.com/t5/Issues/ESRI-ArcGIS-maps-arent-saving-changes/idc-p/1099172#M57047
RenzoFlinterman
Thanks for your update, I think everything is working fine now
FilipFinrašek
Hi, one of our clients is experiencing the same issue. Is there anything happening on ESRI side?
I am now gathering more info from client so I might post some update about it later (PBI version, if it has worked earlier,..)
Thank you in advance for any input.
by Anonymous User
Not applicable
This post is over a year old and based on the older tech that has been replaced. If you are experiencing this, please start a new thread and supply screenshots or videos where possible so we can best identify the issue.
The best way to report issues to ensure they get fixed, is to reach out to Esri Tech Support. As a customer current on maintenance, our support team will spend time learning the issue and coordinate with our development staff to identify a resolution.
