The symbology-style options have completely changed. No transparency option for the color ramp? Is this a bug? I hope this is something that will be put back into the tool.
Having the same issue. Did you find a resolution?
I'm experiencing the same - I had transparency applied under symbology on an ArcGIS map in Power BI. Now options for transparency are missing from the visual, if I update the map, the transparency is gone. No option to re-instate. Would be interested as well to know, if this feature is returning please?
Hi @ecattt2023, @Kristen, and @AndrewTennant , we appreciate you sharing a potential bug with the broader Esri Community; however, Esri does not actively track software defects posted here. The official channel for investigating and validating bugs is Esri Technical Support. All customers experiencing a potential software bug should leverage technical support to report and investigate the issue.
By reporting bugs through technical support, Esri can better track the scope and impact of the issue across all our customers and better prioritize it with our product teams. Our teams can also investigate the issue more thoroughly to see if there is a solution, workaround, or patch to get you back up and running as soon as possible.
As a reminder, Esri Community is primarily a self-service support platform where Esri users can ask or answer each other’s questions, share feature requests, and collaborate to solve problems with GIS.
*Note that this is a scripted message prompted when posts allude to a potential product bug.
