Broken link to reference layer, can't remove from legend
1123
08-16-2022 11:14 AM
KatieIves
I have a Power BI map visual with 20+ layers linked to my organizations content.  Recently, two of these layers are displaying red X's and a pop up appears stating "You do not have access to this layer" linking to the REST service URL.  I can re-add these layers through normal means; they display and there are no issues that I can tell. The issue is that I cannot REMOVE the layers with the broken links, the three dots for the option menu is absent.  Because these broken layers remain, they are causing pop-up errors when trying to access the visual.
Has anyone run into this and know how to solve without rebuilding the map visual?
geckoberyl
I have the same problem...how do I remove this layer?
steviemoxford
Also having the same experience - I simply cannot remove the broken layer  - Please fix glitch
