Connect to a polygon
4425
9
05-14-2018 09:08 AM
Status: Open
UrbisPerth
I need to be able to connect data to a polygon, not just a point. The visual currently lets me have a base map but this only forms a background. I need to be able to attach data to a polygon and colour and shade the polygons. The esri visual does allow for this if I want to attach to certain features within a country but I need to be able to import my own shapefiles and attach data to them. If the esri visual could offer this it would be a major enhancement to the functionality of the visual. The drill down choropleth visual but with mapping (or not if I choose) in the background is the sort of functionality that I am looking for.
9 Comments
YoavRappaport
This functionality is available. You can add your own polygon layers or public layers. These are called reference layers when you edit the map. If you log into your AGOL (and users must have also have an AGOL account to view) you can add layers from your organizational account. Then you can symbolize based on an attribute.
If you don't have AGOL (I assume you do because you are on this chat) you can also import the shapes into the "shape map" visual, however it will be harder to maintain and less basemap and functionality than the Esri visual.
ScottBall
I'm guessing they are asking for the ability to connect tabular data from Power BI to custom boundaries using a common join field. In addition to 'points' and 'standard boundaries' in the location type tool, I believe they are requesting a third option - 'custom boundaries'. A user would have to have a feature layer with their boundaries hosted on ArcGIS and both datasets would need a common join field (feature layer and Power BI data). We've definitely heard this request before and are evaluating it for potential inclusion. Urbis Perth‌ please comment if this would satisfy your needs. Thanks!
RobStover
This would be a huge benefit. With Microsoft essentially tying our hands to ArcGIS maps, linking to tabular data by polygon is a required workflow for essential BI analyses. Something that can be done in Spotfire and other products.
SimonJackson
+1 - Our GIS boundaries are in ArcGIS Online/Enterprise.
As a Business Analyst, I would like to join data from other sources to the GIS layers within Power BI so that I can
perform reporting on them.
I would like to combine/extend this idea to also include polylines.  I imagine a lot of folk with linear assets stored in the GIS, but perhaps business data stored in other systems would also want this capability
KoryKramer
Status changed to: Open
petermcnally1
So, this is STILL not available?  Any alternative solutions?
JanWarnke
We have numerous custom boundaries in AGOL but we need to link to Power BI data tables to do spatial analysis and visualization. Is there  a means to create interactive visualization of custom polygons (choropleth maps)  to client data for interactive dashboards with mapping ?  We need to see the variables mapped when they are selected in the slicers.  Maybe this is a simple question but we are just starting development on our ArcGIS - Power BI journey (new users of ArcGIS - Power BI).Any references or sources of solutions would be appreciated.
SandeshLamichhane
is there any solution?
BennyMeyns
Indeed, we would like to use our ArcGIS feature layers combined with a Power BI dataset, in order to use our ArcGIS layers as a input (selection) to filter our PBI dataset.
e.g. Power BI dataset “garbage incidents”, combined with our ArcGIS “recycle bin 10m buffer” layer.
