Record Updated in a Feature Layer take a long time to trigger flow
819
6
01-12-2023 12:45 PM
DominicRoberge2
Hello
I have to Power Automate flows that are very similar (one is based on a polygon HFL and the other one is a point HFL). Both layers have a refresh interval set to 0.5 MIN. Both layers have a web hook that has been created while building the flows using he ArcGIS Connector, and the frequency is set at 30 sec
So my issue is: When I update a polygon record, the flow is triggered immediately (boom! fast). BUT when I update a point record, it takes 2 minutes for the flow to trigger
What am I missing?
Thank you!
DeloresLoe
Sign in to Power Automate. Go to Data > Connections. Find the connection that your flow uses. Select Fix connections, and then update the credentials for your connection if there is a Fix connection message next to the Status column.
DominicRoberge2
I have no Fix Connections next to it, and both of my flows are using the same connection
SeanKMcGinnis
The webhooks are controlled by ArcGIS Online and there is not much on the Power Automate side where there is much control. One thing I would do - test the webhooks by attaching a test webhook from https://webhook.site/ to see when they are actually firing. If you continue to have inconsistent firing of the webhooks, submit a support request.
-sean
Sean McGinnis - ArcGIS for Microsoft 365 Product Manager
DominicRoberge2
That is a nice tool, thanks for sharing.
Unfortunately for me, seems like the webhook is triggered between 2 and 4 minutes (did 5 tests) which are consistent with I was getting within Power Automate. I will contact Support tomorrow.
Thank you and I will update the post when I get more info.
D
Tiff
Hello @DominicRoberge2, thank you for this post. Have you been able to find more information about this time lag? I believe what I've heard is it is just the expected behavior but it is not ideal, compared to Survey123 connector that triggers pretty much immediately.
DominicRoberge2
Hi @Tiff
it's been a while since I worked on that issue. I did open a ticket with Support and we were not able to find a solution. I did not spend more time on it... just learned to live with it.
Sorry
