Editing the geoportal server catalog
9808
22
02-28-2021 04:24 PM
by Anonymous User
Not applicable
I am trying to add another tab in the Metadata Editor. Basically, I am trying to add a tab somewhere here
with two additional fields that will be saved. Can this be done?
Marten
by Esri Contributor
Like so?
I did this by updating the myprofile files. the attached zip has the files for it.
Marten
by Esri Contributor
hi, this is indeed possible, but requires a few things:
  • If you are adding new elements/attributes, the underlying metadata specification needs to include your additional information also. can you share more on what items you would want to include on the new tab?
  • Geoportal Server includes a number of metadata formats. Although you can build an editor from scratch, typically you would start from one of the existing ones. Which metadata standard are you looking to extend?
  • You will find the configuration files/code for the editor in : ../geoportal/app/gxe/types. In fact there is a sample type 'myprofile' included when installing Geoportal Server.
  • The metadata editor (gxe = Geoportal XML Editor, it can be made to edit pretty much any XML document) uses Dojo and you will find JavaScript files declaring classes and components and a related template file that lays out the components in the preferred order.
  • It is best to start by looking at the 'myprofile' editor to see some of the foundations of gxe. You'll see esri/dijit/metadata/form/Tabs that results in tabs for each of the elements included and then individual dijit references for the sections in the tabs. While you could build an entire editor in a single file, you would be repeating a lot of elements. What the gxe does is break out those reusable elements all the way from a multi-select option list to an entire metadata identification section.
by Anonymous User
Not applicable
Hi Marten,
Thank you for the detailed reply, I really appreciate it.
  • I am looking to include two new items. One would be an input field for Price and the other one would be a Tax dropdown menu with 2 or 3 items in the dropdown - number with percentages (ex. 5%; 18%; 0%).
  • I am looking to extend any metadata, which ever one is simplest to modify /edit.
  • I did find the 'myprofile2' but I cannot find the esri/dijit/metadata/form/Tabs. I presume if I want to add a new tab or new field in an existing Tab, I need to do so in the /Tabs?
Marten
by Esri Contributor
Like so?
by Anonymous User
Not applicable
Yes, exactly like so. Wow, thank you. I now can examine the files and use it for myself.
So how does one apply these new files /tabs /fields to the existing geoportal? I overwrite the existing 'myprofile' or is there another process?
Marten
by Esri Contributor
yep! just replace the existing myprofile folder with the contents of the zip. no need even to restart Tomcat. Just a 'clear browser cache' in Chrome will show the updated editor.
by Anonymous User
Not applicable
I must be missing something, I did replace the existing myprofile folder but it's the same. I can't get the Ecommerce to show.
by Anonymous User
Not applicable
So, I login and go to the Admin menu, I choose Create Metadata and choose the New Document option.
From there, I have the following options
Is the myprofile profile supposed to be here or should I choose one of the above templates /profiles?
Marten
by Esri Contributor
ah, that means you have not yet configured the geoportal to consider myprofile yet. to do so, you will need to edit geoportal\app\context\metadata-editor.js. That file lists the known and used profiles. You will see a list 'allowedTypeKeys' with quite some values. Those values are the keys of the active metadata profiles in your geoportal. You can remove some you don't need and then add "myprofile-iso-19115" to the list.
Then notice the list called 'typeDefinitions'. The entries in this list describe the different metadata profiles by telling geoportal where to find a profile (in the webapp structure) and how to recognize XML to be of the defined profile by an XPath expression ("path"), a criterion ("must":true) and sometimes a value. In that list insert the following JSON object:
  key: "myprofile-iso-19115",
  requiredPath: "app/gxe/types/myprofile/base/DataDocumentType",
  interrogationRules: [{
    path: "/gmd:MD_Metadata/gmd:metadataStandardName/gco:CharacterString",
    value: "MyProfile",
    must: true
by Anonymous User
Not applicable
Yes, that did the trick. I did not know of the metadata-editor.js - Thank you kind sir!
One last question, this custom profile you have provided me with, is based of which profile? I'd like to extend the 'Arcgis metadata' but I will need to examine the custom profile you have made so that I can do it on my own. I need to extend this type
