using predefined symbols when bringing a feature service in to AutoCAD
3508
08-31-2015 08:55 AM
RandallClark2
Is there a way to apply pre-defined CAD symbols to feature services that are brought in to AutoCAD?
DonKuehne
Yes there are two different types of pre-defined symbology that you can use with feature services in ArcGIS for AutoCAD.  One method is to anticipate the layer name and create AutoCAD layers in your drawing where you have defined the default layer symbology for COLOR, LINEWEIGHT, LINE STYLE etc....
The other pre-defined symbology deals with AutoCAD blocks for POINT type features.  You can define an AutoCAD block with the same name as the feature layer and whenever ArcGIS for AutoCAD draws that feature service POINT layer it will insert your block with that name instead of the default point entity.
Here is a video that talks a little bit more about this subject in this video about creating template files:
How to Add ArcGIS data to AutoCAD: Part 5 Template Files - YouTube
DonKuehne
RandallClark2
Excellent. thank you very much.
