Synchronizing Error to server 10.3.1
10933
21
09-24-2015 11:44 AM
CarlosPorras
We are receiving an error while trying to sync updates from feature services on our 10.3.1 server.  Is this an known issue?  Have there been any solutions or work around implemented?  The error is "Error Processing Server Request"
Carlos Porras
Tags (1)
CarlosPorras
Clarification, the sync issue appears to happen when working with versioned data/feature services.
EdvinEriksson
We get the same error message. However, the error remains even after having unregistered all feature classes and recreated the feature service.
Any thoughts on what we can do to resolve this error?
Edvin
DonKuehne
I am also getting the error… looks like a bug. It’s being evaluated.
CarlosPorras
Thanks Don.  Here is the bug info I received from support:
"BUG-000089025-Unable to synchronize edits in ArcGIS for AutoCAD if a polyline layer exists in the referenced ArcGIS for Server 10.3.1 feature service"
EdvinEriksson
Do you think that a new service patch for SQL server could be the source of the error?
DonKuehne
Still diagnosing the issue, we’ve experienced it too. I think it is likely on our side.
JaromHlebasko
Are you able to delete features from within AutoCAD? The only time I get this server error is when I try to update or create features. If I delete features, I can successfully synchronize but when I try the other two, it gives me an error. My features services are set to have all capabilities enabled.
EdvinEriksson
HI Jarom,
We´re also able to synchronize when we have deleted features but not when we have added or edited features.
ChristoforosKatsaounis
Thank you for your inputs everyone.
As Don mentioned earlier this behavior seems to occur due to defect BUG-000089025 which is being evaluated. We should note that this issue was logged specifically to syncing updates from feature services which contain Polyline geometry.
I would be curious to hear if that is the case for everyone in this thread -that would be much appreciated to help us understand the underlying issue and narrow this down further.
