Powercadd (PC9) to geodatabase conversion
894
08-29-2024 04:35 PM
HeatherDavis
I'm looking for someone that knows of a way to convert PowerCADD9 files to a geodatabase. We have over 4.5k buildings in a PC9 file format with information that I'm trying to make available to our organization.
Is there a simple way to convert these files into a geodatabase?
Any direction is appreciated!
DanPatterson
MVP Esteemed Contributor
if pc9 format can be converted to dwg format, then
CAD To Geodatabase (Conversion)—ArcGIS Pro | Documentation
but it isn't listed as a direct import format
Supported CAD file versions—ArcGIS Pro | Documentation
... sort of retired...
DanWade
Hello @HeatherDavis,
Unfortunately, I was unable to find anything from the Esri side, FME in particular, that would assist you. I think it might be best to search from the PowerCADD side as mentioned in this AutoCAD Forum > Converting .PC9 files to .DWG.
