Map extraction / path problem (Arcgis For Autocad 410)
1529
10-23-2022 03:43 AM
michaljanda
Hello,
I want to ask if the "esri_maplayer_extract" function works correctly or where I'm making a mistake
When I use this function: (esri_maplayer_extract 1 "C:\RASTER\TESTING.png")
The map is not saved in the correct directory. It looks like the function ignores backslashes and the directory name is appended to the file name.
Am I making a mistake when entering?
AutoCAD 2020 En
Kind regards,
Michal Janda
DanWade
Hello Michal,
In AutoLISP and Common LISP the backslash is considered an escape character. So, if we want a literal backslash it must be escaped.
(esri_maplayer_extract 1 "C:\\RASTER\\TESTING.png")
https://www.cadtutor.net/forum/topic/49426-insert-quot-symbol-in-a-string/#comment-409254
https://www.cadtutor.net/forum/topic/64553-how-can-i-translate-to/?do=findComment&comment=531755
DanWade
Hello Michal,
michaljanda
Hello Dan, thank you. It works 👍
Kind regards
Michal Janda
