Importing local feature classes/entities
1223
10-27-2014 10:17 AM
by Anonymous User
Not applicable
Hello
Is there any way for importing entities in local feaure classes into their original features service?
This is, a want a draftsman can draw local feature clases in a totally disconected environment, send an administrator de dwg file and upload digitized data....Is this possible?
Thank you in advance
Jesús de Diego
DonKuehne
Yes,  just copy the entities back to the feature service layer.  However, this ONLY works if you are adding new features.
If you want to allow someone to modify feature service feature classes (even outside your organization and disconnected to your network),as long as they are using ArcGIS for AutoCAD to make the edits they can leave them as FEATURE SERVICE layers in  the drawing and whenever you get the drawing back you can SYNCHRONIZE.
  1. Feature Services DO work completely disconnected.
  2. When adding to new features as long as the schema's match you can move entities in a local feature class to onto an AutoCAD layer of the feature service and that will add the attributed feature to the feature service when you synchronize.
-Don
DonKuehne
-Don
