Changing Coordinate System
1061
05-05-2023 11:07 AM
DerekBannon22
I was wondering if there is an easy way to change between coordinate systems when you already have data added to a drawing.
Do you always have to remove all your data and then change the coordinate system or is there a way to change it without removing all your data?
DanWade
Glad to hear from you Derek. Nice to see you are running AFA all the time! You are correct that when Web Feature Layers already exist in the drawing the only way to change the coordinate system will be to completely remove the WFLs first.
