ArcGIS for Autocad install problem
2323
04-19-2021 04:57 AM
LBA
We are just trying to install ArcGIS for AutoCAD on a machine with Autocad 208/19/20 installed on it.
But the install fails with: Required Autodesk AutoCAD.
Any ideas on how to resolve this would be appreciated.
Randy_Garcia
Hi! We support AutoCAD versions 2017 and up so your set up should not be an issue. Can you check to see if you have the following folder C:\Program Files\Autodesk\ApplicationPlugins ?
If not you will have to recreate that folder manually or reinstall AutoCAD as this is the folder ArcGIS for AutoCAD installs into.
JonathanDandois
I was having the same issue installing AutoCAD for ArcGIS 400.2 with AutoCAD 2019 installed. Previously Version 370 installed without any issues.  I created the folder that @Randy_Garcia mentioned, then 400.2 installed just fine, and the ArcGIS ribbon loaded in AutoCAD.  Thanks!
MicheleInserra
Dear @JonathanDandois I’m really stressed because I can’t find a solution to this problem
I have installed two times autocad and I have also reached those folder
Do you have any ideas for another solution?
thank you very much
JonathanDandois
Hi @MicheleInserra , I just had occasion to uninstall AutoCAD (2022) and ArcGIS for AutoCAD (410) and reinstall both and everything installed correctly for me.  I am not sure if that is an option for you.
