ArcGIS for AutoCAD Build 400 - Issues using services published through Pro
807
03-17-2020 01:28 PM
CarltonCounty
Our design team have recently switched to the 400 version of ArcGIS for AutoCAD. The plug-in works well and has great connectivity with AGOL. Due to the 400 version being a BETA and limited information online, I wanted to share my recent troubles with others before attempting yourself.
We have recently started publishing all our services from ArcPro and hosting a map image layer on AGOL for our design team to access from the AutoCAD plug in.
After much testing, it seems that if you publish a service through Pro, you lose all labeling and selection capabilities when you bring the service into AutoCAD through the plug-in. I tried a multitude of options to try and resolve the labeling and selection issue and the only resolution I could come to was to republish the service through ArcMap.
Has anyone else had this issue?
I just wanted to share this with other users, start a conversation and make it know to Esri
by Anonymous User
Not applicable
Carlton,
Are the services public facing? If so, would you be able to post the service uri?
