Validating User-Input in a Smart Form
1329
02-29-2024 07:21 AM
YS2388
Hello,
I am wondering if the following scenario is possible to implement in Field Maps:
- There is a point hydrant layer with a related table for hydrant inspections.
- In field maps, a user selects a hydrant to record a new inspection.
- In the inspection form, there is a field called "Inspection_number" where the user enters the number that identifies this inspection.
What I wish to implement is a validation rule that will check if this inspection number equals any of the other previous inspections for this hydrant. I cannot seem to find a way in arcade that will capture the user input either before or during form submission.
Example:
$feature.Inspection_Number - seems to capture the value that is in the field when the form is opened, which is Null for the most part.
Is there a way to capture the user input as it is being entered or during submission. I.e. if the user enters an Inspection_number that has previously been used for this hydrant, there is an error message on submission.
I appreciate any help.
Thanks
YS2388
Does anyone have a suggestion for a solution to this problem?
ShaunGibbins
Wouldn't it be easier to use an attribute rule to calculate the inspection number? Increment it?
