Unable to change Level of Detail when downloading Offline map from mobile
2965
09-09-2021 10:32 AM
Henry
I've created some web maps with all layers customized and enabled for offline use - however, when I attempt to download an offline map prompted from the mobile version of the app, I am only given the option to download at the Room scale. This is untenable for many of our areas, and when I select the Room text to change the download scale, I get no other options.
Is there some configuration I'm missing that will allow for different scales in the offline download?
I've attached some screenshots of the issue below.
Henry
Henry
Update - I changed the basemap for the web maps I was attempting to use offline and the Level of Detail issue did not reappear.
Previous I was using the World Imagery (For export) Tile Layer from Esri (World Imagery (for Export) - Overview (arcgis.com)) as a basemap in Web Maps for ArcGIS Field Maps and ArcGIS Collector. When doing so I was unable to change the Level of Detail for offline maps created from the mobile device.
I switched it to the World Imagery Tile Layer (https://www.arcgis.com/home/item.html?id=10df2279f9684e4a9f6a7f08febac2a9#!) and the Level of Detail was accessible in the field apps.
Henry
David_Brooks
MVP Regular Contributor
What basemap are you using? is it a custom hosted tile layer?
If you go into the settings of the offline basemap, are all the levels cached ready for downloading?
David
..Maps with no limits..
Henry
It's one of the Esri-provided imagery basemap layers. World Imagery (for Export)
I tried creating some new web maps and the Level-of-detail choices to appear when selecting offline map area do indeed download - and they do download sometimes.
Still having 'Unable to Download Offline Area' messages and Feature tiling disabled errors in the log but that's another issue . . .
Henry
Henry
I created some fresh maps in the New Map Viewer to allow customized conditional forms in the Field Map tool and the issue has returned - unable to change the Level of Detail when adding an Offline Map.
Henry
Henry
Henry
